Hi guy,
I have install south bend stage 3 OFE on my leon cupra tfsi but i have some little noise/rattle/vibration...
Now the clutch have 30 miles but i feel from the beginning a noise from gear and clutch
i explain well.
1) When i push and hold the clutch and push throttle and leave only the throttle at ex. 3000rpm and engine came
back to idle I haven't any type of noise/vibration (GEAR IN neutral position).
2) (ALWAYS gear in neutral position) if i push only the throttle at ex 3000rpm and leave it when the engine came back to idle i hear some noises-rattle (trrrr trrr trrr ) between 1300rpm - to idle and occasionally at idle and i have the same noise with the gear in. but if push again the clutch no noise-rattle.
I want to know if this is normal? for single flywheel or is a wrong installation..???????????????????????????????????????
can you help me? ANY REPORTSSSSSSSS??????????????
thanks all
i explain well.
thanks all
