Speaker crackle
Husbandofstinky
Out from the Wilderness
Nov 8, 2007
1,515
12
Temperate Regions
Probably a silly question but I assume that I'm getting this due to the possibility of wiring being a bit loose.
The Pug estate has speakers in the tailgate and every now and then over a bump a crackle kicks in and continues for the rest of the journey but only on jolts from the road. All very annoying. Its infrequent so I haven't taken the tailgate apart to inspect but suspect wiring may be a bit loose (tailgate closing etc).
I assume that this is the case but I would be grateful for any guidance.
Mar 3, 2009
823
Hinckley
is it actually crackling or just cutting in and out?crackling is normally due to a speaker wire earthing out.
cutting in and out will be a loose connection
Husbandofstinky
Nov 8, 2007
1,515
12
Temperate Regions
Its just crackling over every little bump (after a big one that starts it off). The music is still 100%.
I assume that its a loose wire but I thought I'd ask.
Thanks for your confirmation.
andyj
There's no F in Quality..
Sounds like a cracked solder-joint where the cables connect to the speaker itself, or the small wire that goes from the speaker frame to the cone....
I'd grab a soldering iron and re-solder the joints where the speaker cable connects, and see if that helps ;)
