Right guys,
Recently done the n249/112 bypass and after the car started spluttering! so plugged vag-com in and came up with the fault code:
16684 random multiple missfire
16688 cyl 4 missfire
so presuming it was the ign coil 4, had all coilpacks replaced by the seat dealer, car was then running fine, but today has started spluttering again with same fault codes? also had lambda b1s1 under threshold? the idle also after a while jumps up and down from 800 to 500rpm sometimes?
