Parsy-Cupra
Hi all,
Sorry, bit of a newbie, just got a vag-com on my car.
It splutters between 2500rpm and 3000rpm, the car has ko3s, stage 2 revo, fmic, full blueflame with race cat!
heres what came up
17511 - Oxygen (lambda) Sensor heating B1 S1 Performance too low
P1104 -35 - 10 --- Intermittent
16496 - P0112 35 - 10
16514 - P0130 - 35-00
17956 - Boost pressure regulation (N75) Open circuit
P1548 - 35 - 10 --- Intermittent
16486 - P0102 - 35 - 10
Readiness 0010 1100
Any help explaining these would be much appreciated!
Adam
check your fuses under the steering wheel, cant remeber which one they're linked with though.
im also getting this. please help! i havnt got a clue! you can drive it gently fine but when you toe it and it gets to about 3000rpm it goes onto 3 cylinders!
Yeah it idles allright, does the code say which lambda it is? Also is it saying the n75 valve needs replacing?
Mine sometimes splutters a bit, ad sometimes revs go up and down on idle. Its not major bother but any ideas? I havent gone through any coilpacks properly yet, but im waiting for them to go!
