Its not the wire its the ends that wont hold on, the cables arent made as well as the OEM ones.
I'll double check but think its ok.Thanks for the help though. It's wierd as the window kinks as nearing the top but ive tried adjusting everything but no changeHi there have you checked the bowden cable that attatches the door handle mechanism from the inside is routed correctly. this causes a rubbing noise
