Stage 2 Cupra R - Max 184 g/s - HELP
S50BEN
Hi guys,
I am new to the forum and also new to owning a Leon Cupra R.
The car was originally stage 1 when I bought it which I logged before I had the stage 2 map using vag com, at exactly the same - 184 g/s (same before and after the stage 2 map).
I have just tried cleaning the maf with electrical cleaner and quite a lot of dirt seemed to come out of the maf sensor, although still logged exactly the same once fitted.
The car has a full milltek system with de-cat, green cotton panel filter, forge TIP, forge recirculation valve.
Sunday 20 November 2011 15:47:45
1ML 906 032 A 1.8l R4/5VT 0001
Group A: '003
RPM Mass Flow Load Ign. Timing
TIME
Marker STAMP /min g/s % °BTDC
356.53 5360 10.75 8.6 4.5
357.02 5160 10.64 7.8 6
357.53 5040 11.75 8.2 6
357.93 4920 11.42 8.2 5.3
358.33 4840 11.81 8.2 5.3
358.73 4760 11.53 8.2 4.5
359.13 4600 11.22 7.8 5.3
359.64 4400 10.28 7.5 4.5
360.04 4280 10.03 7.5 3.8
360.44 4240 10.42 7.5 4.5
360.84 3920 9.94 7.1 3
361.24 3360 8.44 6.3 2.3
361.76 3200 9.69 7.1 2.3
362.16 3200 9.72 7.1 3.8
362.56 3120 9.47 7.1 2.3
363.05 3080 8.22 5.9 2.3
363.45 3040 8.14 5.9 2.3
363.85 3000 7.81 5.9 2.3
364.25 2960 7.44 5.5 1.5
364.76 2400 6.72 4.7 0.8
365.16 2480 5.97 4.3 0
365.56 3560 8.19 6.3 20.3
365.96 3480 8.72 6.3 2.3
366.38 3400 8.81 6.7 2.3
366.88 3400 49.61 30.6 27
367.39 3520 99.64 98.4 24.8
367.88 3760 157.5 100 8.3
368.28 4040 159.5 100 7.5
368.68 4320 160.19 100 10.5
369.1 4560 164.11 100 9
369.59 4840 167.33 100 12
369.99 5080 172.22 100 12.8
370.51 5320 176.53 100 12.8
370.91 5520 178.31 100 13.5
371.31 5720 180.08 100 12
371.72 5920 183.33 100 12.8
372.2 6080 184.83 100 13.5
Any ideas what this could be? Before I order a new maf.
Any help will be much appreciated.
Thanks,
Ben
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Hi guys,
Code:
	Group A:	'003
	TIME
Thanks,
Ben
S50BEN
The map was done by DNA tuning, will run some more logs tonight and post them up. Thanks for the help so far!
S50BEN
Ok, here goes:
Code:
TIME	Group 115 - Field 2	TIME	Group 115 - Field 3
STAMP	Boost Pressure - (specified)	STAMP	Boost Pressure - (actual)
	 mbar		 mbar
0.59	990	0.59	1000
1.51	990	1.51	1060
2.42	990	2.42	1090
3.32	990	3.32	1040
4.22	990	4.22	1020
5.13	990	5.13	1020
6.04	990	6.04	1050
6.94	990	6.94	1020
7.85	990	7.85	1080
8.75	2190	8.75	1250
9.66	2210	9.66	1840
10.56	2260	10.56	2250
11.47	2330	11.47	2250
12.37	2340	12.37	2190
13.28	2310	13.28	2110
14.18	2310	14.18	2020
15.09	2270	15.09	1980
15.99	2160	15.99	1860
16.91	990	16.91	1470
17.8	990	17.8	1080
18.7	990	18.7	1050
19.61	990	19.61	1040
20.52	990	20.52	1040
21.42	990	21.42	1040
22.33	990	22.33	1040
44.96	990	44.96	1010
45.85	990	45.85	1040
46.77	1320	46.77	1120
47.67	2140	47.67	1340
48.58	2220	48.58	1710
49.48	2220	49.48	2260
50.39	2280	50.39	2220
51.29	2330	51.29	2280
52.2	2320	52.2	2170
53.1	2300	53.1	2030
54.01	2300	54.01	1970
54.92	990	54.92	1460
55.82	990	55.82	1080
56.72	990	56.72	1050
Code:
Group 31 - Field 0	TIME	Group 31 - Field 1
Lambda Control - Bank 1 (actual)	STAMP	Lambda Control - Bank 1 (specified)
0.984	0.3	1
0.961	1.21	1
1	2.11	1
1	3.01	1
1.008	3.92	1
1	4.83	1
0.969	5.72	1
1	6.64	1
0.969	7.54	1
0.945	8.44	1
0.867	9.35	0.961
0.922	10.26	0.922
0.883	11.16	0.875
0.852	12.07	0.852
0.844	12.98	0.828
0.797	13.88	0.813
0.782	14.79	0.805
0.774	15.69	0.805
0.758	16.6	0.836
0.844	17.5	0.93
1.991	18.41	1.047
1.991	19.3	1.047
1.991	20.22	1.047
1.991	21.12	1.047
1.991	22.03	1.047
0.953	44.65	0.945
0.914	45.55	0.953
0.977	46.46	0.961
0.914	47.36	0.977
0.969	48.28	0.961
0.953	49.17	0.953
0.899	50.09	0.899
0.867	50.99	0.867
0.852	51.9	0.844
0.813	52.8	0.821
0.813	53.71	0.805
0.805	54.62	0.86
0.86	55.52	0.93
1.991	56.42	1.047
S50BEN
Also ran another MAF log, reached 193 g/s today:
Code:
Marker	TIME	Group 2 - Field 0	TIME	Group 101 - Field 3
	STAMP	Engine Speed - (G28)	STAMP	Mass Air Flow - Sensor (G70)
		 /min		 g/s
	0.29	3160	0	77.42
	0.91	3400	0.61	136.47
	1.51	3720	1.21	142.56
	2.11	4040	1.81	147.72
	2.71	4400	2.42	167.25
	3.32	4720	3.02	171.92
	3.92	5000	3.62	176.36
	4.53	5280	4.23	184.19
	5.13	5560	4.83	186.72
	5.73	5800	5.43	188.17
	6.34	5800	6.04	189.69
	6.94	4720	6.64	15.58
	7.53	4480	7.24	10.03
	8.15	4360	7.85	9.97
	8.74	3680	8.45	9.92
	9.35	3440	9.05	8.58
	9.95	3360	9.65	8.86
	10.55	3320	10.25	8.78
	11.17	3240	10.86	8.53
	11.77	3200	11.45	8.5
	12.36	3160	12.06	8.25
	12.98	3120	12.67	8.08
	28.05	3320	27.76	9.44
	28.65	3240	28.36	9.03
	29.27	3200	28.96	9.17
	29.87	3200	29.57	13.53
	30.46	3400	30.17	95.31
	31.08	3800	30.78	163.25
	31.68	4160	31.38	151.86
	32.29	4520	31.98	168.28
	32.89	4880	32.59	174.44
	33.49	5200	33.19	181.22
	34.1	5520	33.79	185.94
	34.7	5760	34.4	186.06
	35.3	6040	35	189.39
	35.9	6280	35.61	191.86
	36.51	6520	36.21	192.61
	37.11	6720	36.81	192.78
	37.73	6880	37.42	193.39
Any opinions on this? Would you say it's running as it should? Thanks
