Standard boost presure ? MK4 Ibiza
Jul 23, 2008
720
Manchester - UNITED
What boost do the standard TDI mk4 ibiza engines run ? I would expect it to be lower on the less powerfull models.
Just curious really, just put a boost gauge in and wanted to see how far from standard i am.
Dan
Mar 8, 2007
831
Mine is standard as far as the ECU is concerned. It has a decat exhaust and pd160 intake, panel filter and CCV Bypass.
It holds 19psi of boost until high in the rev range and drops to 15psi by the redline I think.
Very occasionaly if I floor the pedal in 3rd doing about 50mph it will peak at 21psi for a split second then hold at 19, but it doesnt do it very often.
Jul 23, 2008
720
Manchester - UNITED
Hmm
Thats not too far from mine then.
Mine goes to 1.7bar/24psi and drops to about 1.5bar/21psi but it does this whenever i want to use the loud pedal, so i guess the remap is doing its job then.
Thanks for the input Joel (if thats your name).
Anyone else know what presures they run ? Would be interested to know.
Dan
Jul 23, 2008
720
Manchester - UNITED
RichardBW:
Thanks for that mate, i was just curious really, wanted to make sure mine was about what it should be, i need to get it back on the rollers really.
It pulls like a train so im happy :D
