steering wheel volume control
Telscossie
137
kent
has anyone had a problem with the volume control on the steering wheel on a 2014 leon everything else works even the mute but when i turn the volume wheel either way and nothing at all , thanks
az101
87
14
Burnham-on-sea
I had problems with the steering wheel controls on my 2014 FR ST it went to the dealer a few times for it. Started after the recall for the indicator switch gear and they told me it was caused by a trapped cable. Has been gone for last 6 months. May be worth checking the cables in steering wheel
az101
87
14
Burnham-on-sea
Yeah all original. Been back to the dealer and they sorted it. Diagnosed it as a trapped cable
Sep 11, 2019
Hi there, i have the same problem in my 2014 Leon FR. Is it possible to just remove the steering wheel and fix the trapped cable myself? Or is the cable in the actual steering column as opposed to the wheel. Thanks
az101
87
14
Burnham-on-sea
Not sure, I actually need to look at line again as they have started playing up again now and most of the time the ok button sets off voice control and I can only cycle though the dash screens to the right not left even when pressing left it goes right. If you find anything when you ajve the airbag out let me know as I may have to do the same at some point, just make sure you take battery off before removing airbag.
