Before anyone says it, yes ive searched and havent found a single thread with similar symptoms!
So problem = When at a standstill and in neutral, if i put the clutch all the way in there is an odd scrapping/grinding sound which i can only assume is coming from the gearbox.
The noise doesnt happen unless the pedal is literally on the floor/carpet. If i press the clutch halfway in then pause for a second and put it all the way in again no noise.
The noise doesnt change if a gear is selected and the clutch held in either. As soon as i move off the noise goes away.
Revs dont affect the tempo/rythm of the noise.
Oh and when this happens there is a sort of feedback through the clutch pedal which is roughly the same tempo/rythm as the mystery noise
Although not very loud, it sounds truely rank and as a result im tempted to leave the car at home, on my driveway until i can get a new clutch/flywheel setup and get it changed
Im absolutely stumped as to what it could be so before i go forking out for a G60/VR conversion i was wondering if anyone had any ideas?
Cheers in advance guys
