Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
i bet £20 on n75
How many wires and what color are on the back of your gauge?
I use the F N75, thats the standard OEM for the LCR, part number 058906283F.
I wouldn't replace anything untill i seen some logs, otherwise as the lads above are betting, its only guess work at this stage.
Kit includes: 30psi Guage, t-piece, 2meters of PVC tubing & a bracket - £29.99
From what I can tell the purple wire is the live feed from the lights, black is the earth, orange and yellow I have no idea.
The PVC hose fits over the nipple on the guage easy but getting it over the t-piece is going to be hard as the t-piece nipple is larger than the hose, might need to heat it to get it to slip over.
The T-piece also comes with a metal bung at one end that has a smal hole in it, I assume this is meant to be in there
not worth disconnecting the battery to reset adaption against the new maf?
