Tom problem 3 is probabley "LIMP MODE" brought on by the Lambda fault
Limp mode is more savage though. When my car was hitting limp mode it wouldn't rev over 3000 rpm. From what Tom is describing it doesn't seem as bad as that
Part of the process mate, highs then a few niggles to get you low then back on a high again. I'm sure it will be at it's best asap!
Sounds like limp mode, had this on mine a while ago and no warning lights either
Cheers for the replies! Highs and lows indeed El, have to go through the rough to appreciate the smooth as they say
I'm not sure it's limp mode tbh as the car is revving over 3000rpm. I can't really pinpoint it as there's more than one fault. All I know is it feels like a pig at the moment.
Sometimes the map is there other times not? Really baffling.
Hopefully AmD can fix it all up tomorrow and I can enjoy the 3" TIP and stage 2 as it's meant to be enjoyed..
On another note, I filled up using DIFFERENT petrol for the 1st time since ownership today...![]()
Was in need of fuel badly earlier, but my Shell was shut as the lorry was in there, so went down to Tesco and I stuck in some Momentum 99!!
Yer get proper clamps **** paying there prices eBay do the t bolt type clamps
Tom they should be fine. My car kicks out 1.7 bar and mine are still fine. I did a boost leak test to 2 bar with no leaks. Just do them up tight. Also i re tightend mine a few days after i fitted the cooler.
Are the connecting alu tubes for the front mount not flared?
Sorry to hear that mateThere always seems to be something emptying your pockets
I am going to seriously loose love for the car if the clutch doesnt go smoothly
Only the connector which goes on the drivers side connecting to the upper boost hose off the charge pipe is flared mate.
That one is most likely to pop off, but I think all of them should be flared. Are the lower one's flared on the Forge fmic?
I know tell me about it! I keep shelling out and it wasn't even fun to drive there or back today. Just crawling along with no real decent boost.. Still, hopefully it'll be sorted soon as possible and I can enjoy the map again.
Saw Maz and Rodger (Slick on here) down there in their TDI's and was having a good chat though, and Poverty turned up in his TTRS! I got a sly picture of it
Not sure what he was down there for, I left a bit earlier.
Everything on the Forge kit is flared mate, i wouldnt trust anything that wasnt?
Do you use a ratchet to do up your Jubilee clips or just a screwdriver? Can get them so much tighter with a ratchet.
The TTRS looks the sex, love that car![]()
Tom make sure the pipes and silicone are super clean as any oil or grease will make them slip off. Which pipe has come off. I cant see it being the big 90degree pipe, more likely the small joiner pipe that is beaded.
I would take a bit of really rough sand paper or a stanley blade or dremmel or something like that to rough the end of the pipes up to make it grip better
Tom my suggestion is rough up the ends of the ally pipes and then use JB weld to make a bit of a bead. Worked for many who have gone custom and not purchased pipes with beaded ends. It is this ponsy popping off business why I made sure to buy beaded end pipes
