Those 2 LCRs must have been registered pretty close togther
Try roughing up the pipes for grip and if the clamps keep working loose could drop a bit of loctite on the thread but would be a swine undo again
Love it! Keep the pics coming..
Tom the JB weld stuff is a type of liquid metal, it comes in a tube and harden's when you form it into the shape you want, if your going to the hassle of takeing the bumper off then I would do everything possible to the pipe's to prevent them popping off again otherwise you'll have to take it all off again.
It's just like putty mate, you roll it into a thin sausage then put it around the end of the pipe, it will get hot as you work it.
That sounds easy enough! So basically mould it into a raised flare shape on the end of each pipe mate?
tom has the hose actually come right off, sounds a silly question i know. but if it hasnt could you not lock tight the threat on the clip and do it right up. if the hose has completly come of you would have zero boost, not even 0.1 bar.
nice pic by the way![]()
Yep thats it![]()
nice car mate. love the grey colour. probably my favorate.
tom here is a good guild, i might do this myself as it looks so easy
http://dsm.fidke.com/articles/diy-bead-intercooler-pipes-with-jb-weld.aspx
Just buy decent clamps.
