tail light problem
2footpegs
117
my driver side taillights has stopped working, ive changed the bulbs, swapped over the holders with the pasengers side and checked the fuses but nothing seems to work. i installed to auto gauges the other day o im thinkning i may have messed up a connection, which wire would be respnsible for the tail light not working?
thanks
dg-1984
254
Glasgow'ish
Check fuse, then would check that they have a good earth connection, then with a multimeter check the supply voltages etc.
2footpegs
117
yep iv check the fuses they seem fine, how do you check if they have a good earth connection?
Haggistech
63
why not take the gauge back out and see if that fixes the problem
do one thing at a time and cross them out as you go
