Tappety TDI
muddyboots
Still hanging around
Oct 16, 2002
5,739
When I start my Passat the first time each day, it makes a tappety noise for a few seconds until the oil pressure is up, then it goes quiet.
If I stop and start up again later in the day, it's fine - only makes the noise when it's been stopped for a long time (ie overnight).
I know it's covered 100k now and isn't meant to sound like new, but is there anything I can do to help ?
It's service time now, I was wondering if using some flushing oil would help, perhaps the oilways to the tappets are a bit clogged :shrug:
Any suggestions ?
EdButler
713
Sheffield
Muddy, mine has done exactly the same when it went into the the dealers (twice) - Its the only time it doesnt get driven for 12+ hours and made a tappety noise which soon disappeared - never heard it since.
Mike_OBD has an 05 with about 22k and his does it occasionally. It could be just a sticky tappit. I dont think its anything serious at all, ill ask Mike to see what the JBS chaps thought of it...
cheshire cat
1,813
cheshire
it's a hangover from pushrod-rocker and valve stem days. I guess now, it's the part which allows for a clearance between cam and the end of the valve whatever is inbetween the two. Muddy, does your filter have the oil dam inside, if not try a genuine part
muddyboots
Oct 16, 2002
5,739
Hadn't thought of that, but I would hope so as it's only ever been serviced at VW until now.
I will be buying a genuine VW filter though, plus a can of Millers.
Might get some flushing oil too, guess it can't hurt after 100k miles, bound to be a bit of gunk in there !
OK another question:
How do hydraulic tappets work, I presume the oil must get pumped in somehow ?
craig-pd130
353
Manchester
Yeah, they've got little inlets and outlets, the idea being to maintain a certain pressure in the tappet (but not so much that they "pump up" at higher rpm). Over time the oil inlets / outlets wear a bit and let more oil drain when the engine's stopped than normal. Hence the tapping when you start from cold, while the tappet fills up again.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
The tappet is present in most engines as a cam follower, and is often the location for valve clearance adjustments to be made. Some overhead cam engines, though, have the cam acting directly on a rocker arm - the VAG 24-valve VR6's work like this. In these cases a bucket tappet can be located over the valve stem.
http://www.autozine.org/technical_school/engine/tech_engine_packaging.htm
For a long time, valve clearances were adjusted by hand at service intervals, either by a screw-and-locknut on the rocker arm or tappet, or by shimming the tappet to the correct clearance.
Nowadays most engines use hydraulic tappets which are self-adjusting.
http://www.tpub.com/content/construction/14264/css/14264_91.htm
Engine oil pressure is what forces the hydraulic tappet to take up the clearance, which is why you sometimes hear a brief clatter on startup. The tappet includes a calibrated bleed so that the expansion of valve stems and other engine parts can be adjusted for - the tappet is able to slowly change its length while still acting as a solid connection for the duration of the valve opening event.
