Charliemonkey
23
Hi,
2015 FR 184 ST, just got the car after 5 years and 100k in a mk1 Cupra TDi, I like it a lot but it's showing the above codes which I think is the power to the throttle valve, guess its stuck causing the fuse to blow. Does anyone know where the fuse is please? Does anyone have a complete fuse diagram for the car, the manual says there are other fuses somewhere besides the ones in the engine bay box and the ones behind the glove box. I can't get the links on the Set manual site to open......
Thanks.
The throttle valve is just before the inlet manifold charge cooler, took the airbox out and took the induction pipe off. The valve was clean so pushed it manually through full travel several times to check it sprang back to the fully open position. Put it back together and no fault codes so far, maybe it was a bit sticky?
