Had the red light on temp gauge beep at me a few times when its been cold. Checked level and all seems ok. Took it to stealers and they said couldnt find anything wrong. No leaks or faults etc. Rang different dealer and was told its a warning that outside temperature has been below 5degrees. Now my old Golf used to beep at you when you were driving along and temperature outside was less than 5degrees but the Leon has never done this. Leon is beeping when started from cold. If you turn engine off then back on again it doesnt beep. Am i being fed a load of crap from dealers or is it correct what they are telling me? Dont know why i bother even ringing them apart from the cars still in warranty!!!!!
