argyll2bikes
Hey
My cardoba vario 1.6s/.cool with an alm engine temp sensor has major problem. Replace the sensor 4 times with the same result no change in the problem so changed the coolant and lambda sensor water pump was replaced at 80k changed sparks and coil and ht leads.
Any ideas? Also wont pass its mot on emissions its doing my head in
cheers chris
Have you checked the thermostat and housing? The housing often breaks leaving the stat itself looking fine.
hey, i havent checked it. Where is the housing located?
cheers chris
It's holding the stat in place in the return hose. (the one furthest back). Make sure there is no pressure in the system before opening anything though. I still have scars on my hand and wrist!
