They deplete over time and start logging fault codes sometimes around 5 years old.
5 years service out of 3 x AAA batteries isn't that bad in the grand scheme of things.
And my two pennies worth:They deplete over time and start logging fault codes sometimes around 5 years old.
It is not clear to us mortals what this "reset" action entails. Does it have to be done online only via ODIS so it can pull original configuration of the control unit from VAG servers? Or is it just an initialisation thing that is done offline, maybe even using some reset function under basic settings in OBD11?Once the battery has been replaced, the module adaption values need resetting.
What i wanted to know whether it was an obd11 clear errors rather than ODIS.It is not clear to us mortals what this "reset" action entails. Does it have to be done online only via ODIS so it can pull original configuration of the control unit from VAG servers? Or is it just an initialisation thing that is done offline, maybe even using some reset function under basic settings in OBD11?
I've only ever used ODIS to carry out the process. It basically tells the OCU that the internal battery has been replaced.
I would imagine that other systems are also capable of carrying out the reset.
Yes, I would imagine that the second option would do the trick.OBD11 has some functions under Basic Settings for Telematics unit, only two of them look like they might be related to this reset action:
"Resetting of all adaptation values" (sounds a little scary)
"Resetting the history of the emergency call battery"
(Maybe this is the equivalent of the ODIS function?)
