Pictures would help no endthe link you posted is 1 way of doing it but it dont really gain anything its just moving pipes. FPR goes to the inlet mani 1 direct feed then dv to mani 1 direct feed if you want to install a boost gauge T in to the fPR vac will give you a good reading.
The other pipes you leave open on the side of the head if your not sure blow down then an find where the air comes out that way you no nothing is using it if that makes sence.
hope that helps
You wouldnt believe how many people drive to me for work. 1.8t stuff is all I tinker and build. Get a dv on and it should be ok. Ebay is the way forward mate. And you will have BOOOOOOST
Yes ill have a look at the pics an go from there.
Right after getting my car back off my lass as she's been driving it all week another thing as come up witch she didn't tell me. When driving in any gear and let off the throttle so it's using the engine to slow down there's a scraping noise but dip the clutch it goes away or put your foot on the accelerator and it goes away just when you let off the throttle in gear if its ticking over clutch in or out no noise as I thought that could be the release bearing?
