jcbmally
Dec 26, 2013
1,271
550
Cybertron
As per title.
  • Interior map lights are dimable (press and hold)
  • Only realised today I can lower my boot floor height :doh:
  • Can set tailgate height, SWMBO is only 4’10”
  • Press and hold “view” on SW and it minimises some of the info
  • Set limiter (cover on another thread)
    I’m sure there will be other stuff I’ll add.
As per title.
How do you set the tailgate height?
Reactions: jcbmally
Manual, page 103. Might be different page for other language:
Interrupting opening or closing
After beginning to open or close the rear lid,
the action can be halted by pressing one of
the boot buttons.
Modifying and memorising the opening
angle
If the space behind or above the vehicle is
less than the travel area of the rear lid, you
can change the opening angle of the rear lid.
To memorise a new opening angle, the rear
lid must be open at least halfway.
● Interrupt the opening process in the desired
position.
● Press the boot button ››› Fig. 78 on the rear
lid for at least 3 seconds.
The opening angle is memorised. Memorisation
is indicated by blinking of the hazard
warning lights and an audible warning.
the boot buttons.
angle
position.
You beat me to it :thumbup:
I'd just have her use the easy open / close... the tailgate not going up fully would bug me too much!
Reactions: jcbmally
My in-laws have a low ceiling garage. I don't use it often but I was worried that when I do, we'll open the tailgate without thinking and damage it on the ceiling. I'd love it if it had some kind of sensor to stop that from happening but I would be surprised if that exists.
Reactions: jcbmally
I may have to adjust tailgate due to garage door going up and hanging well below ceiling. Couldn't find any info how high tailgate goes. I didn't have any hatchback for years, so didn't have to worry about it.
Reactions: jcbmally
Probably very basic but I assumed the ambient lighting was on all the time. However I've established it is only on when the auto sensing camera recognises that it's dull enough to have it on/when you manually over ride the auto lights by putting your lights on. In short ( if its glorious sunshine there is no ambient lighting) so don't panic if you don't see any in the sun like I did today and pulled over and spent 15 mins trying to sort it.
Can you tighten the side bolsters with the electronic seat control. I've had a little play and can feel the lumbar support reacting. Was wondering if you can tighten the side bolsters though... Not a huge issue if not as they hit you pretty well anyway
I discovered it on a test drive. Wanted to play with colour settings and there was nothing on. Salesmen told me later it only works when lights are on after dark or when you switch them on manually.
I only told a few people about ordering new car and in most cases referred to it as Cupra, didn't mention model.
My neighbours reactions should be interesting. We have mostly VAG + German cars in our small close and there's one Arona, so they shouldn't have issues with recognising Cupra.
Keyless operation and reversing camera work as intermittently as AirPlay.
Theres some really good tech in the car, but I don’t think the operating system is up to it all - bitten off more it can chew!
Could you explain more on what is wrong with keyless operation ? Do you mean you cant lock or unlock ? Does the reverse camera not engage when selecting reverse gear ?
Mine works flawlessly everytime...
Keyless sometimes works, but sometimes needs to be locked using the key rather than using the door handle (appears to need reset every now and again).
Reversing camera sometimes comes on, sometimes doesn’t and the screen just stays black.
CarPlay often requires to be selected when I get in the car.
Just a few annoying gremlins.
Im back to the dealer in a couple of weeks to get my service schedule reset (they forgot to do it when I collected), so if these things don’t settle down, will get them to look at them.
Sounds like you need a software update or reset, mine has worked fine since the initial update (third day) when it stopped recognising my key, but once updated, no problems since?
Is there a way to force an update?
