This heat is melting my door!
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
It's the rustproofing compound from the inside surfaces. It used to dribble from the tailgate of my Mk.2 Ibiza and make an incontinent trail down the bumper. Kept it up every summer for the six years I had the car.
Ol' Timer
873
Norfolk
Hicks said:
So do I have to do anything about this? Is my door going to rust to bits this winter?
When they build the cars they flood all the cavities with wax to prevent rusting. Most of the excess drains away through the drain holes but there will still be a few thick patches left. The hot weather is just melting the wax and gives the excess a chance to escape. I think there should be still be plenty left on all the surfaces to prevent corrosion. Cars have been doing this for years.:)
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
The reason it is leaking out is that you have an overgenerous coating on that panel. Your other doors and tailgate aren't leaking, but they're still rustproofed.
The only thing you should do is make sure the wax doesn't bung up the drain holes when it hardens, or your door will fill up with water the next time it rains.
Hicks
Let's nuke 'em from orbit
Nov 26, 2002
420
Relocated Yorkshireman
mr_claypole said:
i had that on the lcr, leaked out of the front wing and onto the light...
make sure you get it off while its HOT... its a complete biatch to remove when its cooled down...
J
Too right. It solidifies and you virtually have to chisel it off. Seems to collect on the door sills.
