turbo_scotty
Hi guys this may just be me or may just be my car but its done it ever since I bought it when you change gear the revs seem to take forever to fall is this normal ? My mates 20vt passat as soon as you touch the clutch it's back to idle ? I've changed clutch switch this is working spot on now ( have my own vagcom ) maf seems to be working fine . I haven't got a boost leak as I've pressure tested the system ?
So basically the revs just seam to take ages to fall between gear changes kinda makes you sound like you can't drive sometimes
Help ! Thanks in advance
Scott
