Throttle hang ?
turbo_scotty
Hi guys this may just be me or may just be my car but its done it ever since I bought it when you change gear the revs seem to take forever to fall is this normal ? My mates 20vt passat as soon as you touch the clutch it's back to idle ? I've changed clutch switch this is working spot on now ( have my own vagcom ) maf seems to be working fine . I haven't got a boost leak as I've pressure tested the system ? :( :( :(
So basically the revs just seam to take ages to fall between gear changes kinda makes you sound like you can't drive sometimes
Help ! Thanks in advance :) Scott
turbo_scotty
Ok guys ill give that a go and ill let you no how I get on :)
vagman2001
89
Iv got this problem too removed tb and cleaned it a couple of weeks ago but only got my cable the other day...gonna reset it in a bit and ill let you know how it goes!
Mikey_Bling
369
Notts
How easy is the TB to get to anyone? Mine does the same on the revs mate. Pulls just fine, but seems to be a slight delay when coming off the loud pedal for the needle to drop.
turbo_scotty
Ok so I removed and cleaned tb and did r reset via vagcom and still the same ? I've read somwhere on the net that mabie my thermostat may be stuck open slightly causing the slow falling revs ? Any other ideas ? Cheers guys
