asquith_4
Fr -260
Feb 15, 2012
41
Hi guys not to sure on this so any help would be great
I recently plugged into vagcom to check my throttle positions/sensors and getting a few problems
On Tickover these were the results
17: throttle position sensor 12.2%
69: relative throttle position 2%
71: absolute throttle position B 12%
73: accelerator pedal position D 15%
74:accelerator pedal position E 15%
76:commanded throttle actuator 2%
Thanks for any help :)
Its normal, my throttle position was 17% if I remember correctly. There are a few threads on this is you do a search, I wouldnt worry unless it is affecting the way it drives :)
Cheers for that wasn't to sure on it
The only reason I asked is because sometimes around 70-80mph the car drops boost and goes into somekind of limp mode but no warning lights just throws a low fuel pressure code up and someone suggested it could be the throttle calibration?
So thought I'd post the throttle results up
I'd check fuel pressure on vcds.
Check its pressure from the tank and also log it's actual vs requested on the high pressure side.
If you can log these and replicate the problem that will give you your answer.
Have you replaced or checked the cam follower on the high pressure fuel pump recently?
I'm assuming this is 2.0 tfsi if so what age is it?
Hi yes its a 2007 tfsi fr
And yeah changed the cam follower a few weeks ago
I will check the fuel pressure tonite when im home and then repost
Thanks for your help
