Nov 23, 2026
Hi guys, I’ve got a strange issue that started happening recently.
Seat Leon Cupra st300 4drive & DSG (2018, dq250) with98k km.
Changed tires from summer to winter (SC7 to Hankook icept evo3) on the same set of rims (original 19” rims) - since that moment, I’ve got a thump/thud and vibration feeling in the floorboard after hitting 20mph. It feels like a click and it’s speed dependant.
It does it while cruising, coasting in N or breaking and downshifting, only after 20mph. If I’m accelerating hard and I stick with it, I can’t feel the thumps anymore.
I checked the tires and they had some bulges so decided to go for a brand new set of Hankook icept evo4. Mounted them again on the same rims, and to my surprise the issue is still there.
Note that there’s no audible noise, clank, hum or anything out of the ordinary apart from the normal winter tires noise. It’s just a sensation like a thump in the floorboard, parallel to the DSG gear shifter. This thump is felt on driver and passenger side and the vibration is felt through the steering wheel as well (slight, no play or movement in the steering wheel, just sensation)
What I’ve checked until now:
- tire pressure (tried 2.9 bar, 2.7, 2.6, 2.5 - across both axels - no difference)
- rebalanced the rims (once with the evo3 tires and second with the evo4)
- swapped front to back
- changed oils in front and back difs plus haldex and DSG
- checked the rotors (dba series 5000 - 8k km usage only street) not to be warped (I’ve got no vibration or steering movement while braking)
- checked the CV joints and axels and only the rear right side has like a 5mm play which I find very acceptable
- did the alignment on both axels (only front right could be set full in spec in camber, but it’s a 0.07 degree deviation)
- changed the dogbone mount (went for lemforder) as the OEM one was aged
- inspected the giubo (no play, no cracks)
While we raised the car and put it in drive at that speed, we couldn’t feel anything in the floorboard.
I don’t have sort of clanks or noises when accelerating while turning, or going more aggressive from a standstill (things that would indicate a CV issue) and I also tried to rev the engine in neutral at the same RPM I can feel the thumps while driving and it’s not doing it.
My mechanic told me that he suspects the wheel bearing (but I don’t have a hum and I changed both front bearings 4k km ago) or that all rims are rounded, but this doesn’t explain why with the same rims on summer tires I haven’t had any issues.
Could it be due to wheel bearings failing again?
Any ideas?
