aidenflannigan
Help! Can anyone help with part Numbers? I own a 2002 Leon Cupra and its long overdue for a belt change (80,000miles) the thermostat has siezed open so will need changed along with the water pump. Would be grateful if anyone can help and suggest any other components i will need.
You can buy it as a kit where you get the cambelt and tensioners.
Then you need water pump as you said
For thermostat you will need the O ring/gasket and some G12+ coolant.
Many thanks i've just found a thread which details the same job on an 02 1.8T golf so it should answer most of my problems. thanks for the hint regarding the O seal for the thermostat.
