I bought non genuine ones for mine, £9 a side for top mount and bearing but no nut
Thats for the fronts.
Handling wasn't considered important on your car....?
Hi thought id write the part numbers here in case people want to order some in the future.
FRONT TOP MOUNT - 1ML412331
FRONT BEARINGS - 1J0412249
NUTS - N90353603
Dont know what to do now coz no ones got any in stock and i really wanted to fit the coilovers this weekend. Dont powerflex or superpro do these?
What about the rears?
I'd fit the coilovers with the old top mount bushes and bearing and hope you don't break the bearings on the way out.
Just replace these when you get the new ones. Not too bad a job to do, worst bit is removing and refitting the strutts/coilovers
What coilovers did you order?
If these have rebound/bump adjustments then there might not be a 7mm allen key recess and you might have to use the supplied bolt with these.
But new bolts are not expensive and better to have as spares than not have and need them
