rocketmanbdl
Do Ibiza's suffer from torque steer? especially the tdi's? My FR tdi pulls to the left, I just wanna know if this is normall? Cheers
is it severe? But yeah even my 1.3 diesel van suffers from torque steer.
it's only slight under normal driving which kinda makes me think its something different, but when u floor it really does try n go off to the left. I've heard of clio 182's having this problem. I'm gonna see what happens when i brake
welcome to the site rocketmanbdl :wave:
is it when your accelerting or when your driving along and let the car go where it wants to it pulls left??? as it is a VERY common problem the beezers all pull left very slightly or in some cases alot. but if its torque steer mine doesnt torque steer that much!
oh right, yeah if i'm driving down the motorway it will change lanes for me almost, it does seem to be worse the slower i go. I was just worried something more serious was wrong with it, but if its a common problem then no worries. 1.9pd 130bhp awsome engine!
they all pull left for some unknown reson only thing i can think of is where they are made in spain they drive on the right hand side of the road maybe they have made it so the car fights into the road CAMBER slightly so it stays in a straight line but of course for us driving on the left it makes it worse :(
my car does suffer a bit when i floor it it try's to take the wheel out of your hands but its not massivly it didn't when i just had a re-map :s
so what happens? does more power go to one of the wheels? would a re-map solve the problem?
I've read about this on here before but strangely mine stays dead straight.
Maybe the alignment is out and so it counteracts it :p
the poiwer will go to the n?s wheel as the driveshaft is shorter but this only realy applies to grip/wheelspin rather than pulling left
kriso- quite alot of people dont have problems but this is a common fault with most beezers as long as my tread wears evenly which it does even with coilovers im happy just hold on tight to te steering-wheel :D
I used to have this problem till I hit a road sign that had fallen over coming through some roadwork’s, seat redone the tracking and now it pulls to the right!:think:
Weird thing tyres wear evenly, so not overly conserned as the tracking is right
as rash says his car dosent suffer from it mine didnt and they have been most powerfull petrol ibiza mk4's. and what yes they do seem to vear left but get a 4 wheel alignment done and that sorted mine out.
if it's a case of the car wandering left when your cruising down the motorway it sounds like you have a wheel alignment problem, most tyre places can do basic wheel alignment
or you could have a void bush failure that is making one wheel sit squint and causing the problem under hard throttle/power
void bushes or cupra void-less bushes can be fitted quite easy
mine steers to the right oh so slightly in 2nd
and it's good to hear about pulling to the left... thought i'd have to get my wheels all checked before i get the wheels fitted!
If it's that bad, and only happens when accelerating or braking, then it sounds like one of your suspension bushes has gone - allowing the geometry to change under load.
(In which case the tracking you've already had done will be meaningless anyway!)
Torque steer happens when you really boot it; it's an urgent, tugging of the car one way that feels 'out of the oridnary'. I've only had torque steer on wet roads or loose surfaces, usually pulling away quickly using second gear.
A car veering to one side all the time is another problem.
Mine doesn't do this anymore - its lowered 85mm + and got bigger/wider wheels/tyres :)
That's the cure... lower it, get 17's with wider tyres :D
crimbo for me :D i'm going to get coilovers, wheels, brakes and spacers all done at the same time for maximum effect :D
