May 31, 2008
1,247
So i finally had the tracking and camber done front and back. The thing is the car wasnt as low as i wanted it before i had it done. I was just wondering if it would be ok to lower it some more, or would i have to get the tracking and camber done again to stop the inside of the tyres scrubbing out?
i'd say the back would be fine as its a solid rear axle so camber doesnt change through the suspension travel.
lowering the front a bit would give a slightly more negative camber but shouldnt affect the toe angle,
probably alright if its only minor adjustments!
Only about 10mm on the front and probably nothing on the back. I just want it that little bit lower on the front. So it should be ok?
Thanks guy :)
ye would have thought so! though no one wants to be responsible!
tyre pressures etc will make a much bigger difference than that anyway!
Ok will give it a try, if i start seeing scrubbing guess i will just have to cough up the £25 lol.
Ok so I lowered her about 1cm today, seems to be a bit more bumpy. Might get the tracking and camber done when i get back from holiday. Just as a precaution lol.
