Translation of logs
sargey
Escaped mental patient
Aug 16, 2006
324
Weston-super-crapland
Ok, Finally got a full licence for vag-com and took 2 logs, one at idle one at driving (got stuck in traffic on dual carriageway tho)
First log shows mainly about the cat sensor voltage. I noticed it wasnt anywhere near the parameters shown (below 1v)
and the other log just shows important running info, revs,intake temp etc
can someone look at them and just see if anythings wrong? (illemail them as i cant upload them for some reason)
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
Right mate, those logs are useless as far as logging performance or temperatures are concerned, you ideally want to get decent run from around 1500 revs to redline in 4th or maybe even 3rd gear if you can find a long enough road.
Depending on what you want to log you will need to choose the blocks, ie do you need to see boost, air flow or temperatures etc.
the 0-1v doesnt necessarily mean its going to be between 0 and 1.
