ja88thfc
im ordering a new key from SEAT Cheshunt on Saturday, he said
Key- 40 quid
Remote -40 quid
programming -40 quid
Key- 40 quid
Remote -40 quid
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
well i've just ordered x2 transponder ships - should be here for weekend and will look at moving forward then
Key- 40 quid
Remote -40 quid
Have you read any of this thread or others?
You can get it done for £50 or less in some cases.![]()
Can I just ask if anyone can confirm how it is re-programmed?
I lost my Central locking key and am just left with the key that you physically have to use in the lock to open the doors.
I'm gonna buy a new key, or even a flip key from ebay, and am gonna delve into VAG-Com to program it.
Do I need to program the physical key at the same time? (i.e. does the CCU remove all programmed keys when I program the new one)
Do I need a Code to put into VAG-Com before I can do anything?
You will need your SKC code before you can do anything key related on VAG-COM. The car will not "forget" your other key unless you tell it to.
If you don't have your SKC, you'll need VAG-Tacho to extract it from your immobiliser. If you're near North Yorkshire/Teeside, give me a shout and I'll do it for you.
