TT rear disc conversion
andy_gdon
494
m0rk said:
How does a mechanical braking system adjust?
All that happens at best is the rears lock up (they're unweighted) and the ABS kicks in, and you don't slow down as quick
really - you are making some pretty dumb assumptions that not only endanger your life, but the people you're about to run into.
taking the standpoint of 'uprating the fronts & rears' both at the same time is great - but unless either of you measure, test measure a whole lot more then you don't deserve to have cars.
You could buy and fit brake bias valves, but somewhere along the line, I think that might be beyond you.
Not sure if this is related but i'll have a stab!! When i lowered my Corsa 60mm i had to adjust the rear bias something (i cant remember what it was called-too long ago) What i found was that because the rear was so low the car thought that i had extra weight and applied too much pressure on the rear brakes-causing all sorts of fun!!
Would this be the same type of thing you refer to m0rk??
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
Load Dependant Valve - and they're not that reliable as m0rk says
