Turbo change...gasket help
ben_edwards30
304
Shropshire
Hi, I’ve just changed the turbo on my 1.4tdi ecomotive (2010)
I need to change the small gaskets. Two on the exhaust part (small pipe) and one on the inlet side (egr side, small pipe)
The gaskets all pretty much look the same small centre hole around 20mm with two bolts.
Does anyone know wheee I can order them online, have a part number or diagram maybe. Even a link? I can’t find them anywhere and don’t have a dealer near me.
thanks for any help
SEAT Rule
188
62
thanks for any help
Hello there,
I've only just seen this but looks like you've posted in the wrong model section, if you'd posted in the correct section under MK5 Ibiza 2008 to 2017 this might have been spotted sooner.
I've had a quick look on the ETKA parts site, regarding the gaskets you need. Looks like your Ibiza is a 3 cylinder Tdi with engine code BMS 1.4 with roughly 80 BHP.
Oil return pipe from turbo
Part number 045 145 736E
Gasket for return pipe above
Part number 03L 145 757M
Bolt for return pipe above,
2 of these bolts are used.
Part number N90 592 703
EGR valve
Part number 03G 131 501N
EGR pipe
Part number 03G 131 521R
Gasket for above EGR pipe at flexi end
Part number 03G 131 550
The other end of EGR pipe has this gasket below
Part number 069 131 547D
Exhaust manifold gasket
Part number 045 253 039B
All the above I think is on Ebay, well the gaskets and EGR pipe are anyway.
Hope this helps
Si
Reactions: Woody_72
