Turbo cooling?
Imperial
126
7
We've just added a mk1 leon cupra (2003) to our 2001 ibiza cupra. The ibiza continues to make a noise after switching off for 10 minutes. I always believed that this was the coolent that continued to flow to cool the turbo. The Leon doesn't make the same noise afterwards. Can anyone shed any light on:
a. Am I right that the noise is the cooling?
b. Should the leon make the same noise?
Thanks in advance.
The MoffMeister
Half Hoff, Half Moff.
Apr 4, 2006
2,937
colchester
some leons do as far as i know i think its the cupra r that does as mine doesnt and its an 02 LC, and yes the buzzing is cooling it down although are you letting it cool for a few minutes before turning off??
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
The noise is a water pump for cooling, and as far as I know the Cupra R is the only one to have it? Could be wrong though.....?
SteveaB
The buzzing on my R sounds like somthings shorting out when the engine gose off!
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Mines does it a few times! when i drive hard! The 2fans kick in after i turned off and locked the doors! They stay on for around a minute aprox!
Does the water pump be runnin as well?
RobM
Sep 27, 2006
4,982
Southampton
Fans and the water pump are two separate issues. The fans will kick in on any car that has reached high enough temperatures. The water pump is something separate totally.
omg!
83
Fife
The water pump is an electrically driven pump fitted to the LCR which circulates coolant round the turbo for 10 minutes after switching off the ignition. It does it everytime regardless of temperature.
omg!
83
Fife
Not as far as I know. The schematics for the engine show a secondary coolant system which is electrically driven and just appears to circulate coolant round the turbo and cylinder head after the ignition is turned off. I am not a techie, I just looked at the pics so I may be wrong.
Big_daddy
Oct 20, 2006
3,930
Brummy
so basicaly a turbo timer is waste of money espically for cupra r! as it has it own coling system built in!
omg!
83
Fife
It would seem to be a bit of a waste of money to me as the cooling system is still going to run for 10 mins after the turbo times turns the engine off. It may still help though I guess.
Imperial
126
7
Thanks for the thoughts fella's. Seems a bit strange to put the cooling on the ibiza and the LCR but not the Leon Cupra. Will definetly have to be more careful about letting it cool down properly!
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
my LCR doesn;t seem to make that noise, think i read summit on here with a wire or switch behind the bumper thats normally the problem if it doesnt cool down automatically! cant find the post or even who posted it! anyone help!
RobM
Sep 27, 2006
4,982
Southampton
BCM - If you're doesn't sound like the pump is running, I'd make sure you give the car a nice long cooling down period before shutting off and I'd get the car into Seat or a VAG independent garage to be checked out. Cooling the turbo properly is very important.
BCM
Keyboard Gangster
Feb 1, 2005
2,680
i ALWAYS allow cooling preiod, whether its sitting in my drive running for a few minuets or taking it easy for bout 2 or 3 miles on the way home (below 2.5k rpm) just to allow it to cool a bit better, need to check for that self cooling thing tho, its in for a service next friday so will get it checked then!
