greg
Newbie
Aug 31, 2005
256
Is anyone running a set of OZ ultraleggeras with brembo calipers fitted? If so, what offset are your wheels, and do they require a spacer?
Cheers,
Greg
I am also running ultraleggeras with Porsche Boxter S Brembos and i have got 5mm spacers as without them they was only about a papers width gap between the inside of the spokes and the caliper. Im afraid i dont know what the offset of my wheels are though
Yeah, i just wasnt sure if there would be any movement so i just played safe and stuck on the 5 mm spacers, on the fun side the back end is nice and lively and i find that it handles better.
Mine are 17"
Just been offered a set of superleggeras off a mate for next to nothing so gonna go with these and get 5mm spacers.
Do any of you gus know the best spacers to get?
Im assuming they are non-hubcentric also as searching on here it appears they dont make hubcentric less than 10mm.
Also, do i buy spacers for the rears also just to even it up?
Cheers,
Greg
See if you can get ET35. Might not need a spacer then. Cant get hubcentric any lower than 10mm as you have found out. With 5mm spaers consider longer bolts.
Thanks Guys :D
Also, do i need to get spacers for the rear to even it up or is it just personal preference?
