Urgent help coolant leak
Cupra panda
26
Stevenage
Hello I'm having issues at the moment where my coolant is completely draining
It's coming from the left side between air box and under the recirc valve there's a small pipe that comes of the main radioactive hose and tucks under the block I have no idea what it is also may be leaking from the silver valve looking thing that's in that area not sure any ideas
Thanks in advance
Cupra panda
26
Stevenage
Radiator hose Lool sorry didn't see that and can't put photos up ?? It's next to the air box under neath the recirc valve the main hose that comes off top of radiator links to smaller hoses and it goes under past the egr valve I believe it is
DrewCole
Spannering the Cupra
Oct 19, 2015
697
Braintree, Essex
You'll need to host pictures yourself on Photobucket or similar and post the link.
OR
If you use Tapatalk then you can upload them straight from your phone, which is what I do and is very easy.
