starkygti
109
hey guys the cupra died on me the other night turbo had no power and started running really lumpy as if only firing on 3 cylinders. called aa we played about with the coil packs put one new one in and the car seemed to idle properly but still no turbo. got it plugged into the vag com last night and threw up boost pressure control valve and 3 misfire faults one in any cylinder one in cylinder 1 and one in cylinder 2. what do i do help please. my turbo doesnt spool at all. all help appreciated thanks alex.
just the one but the aa guy said to try the plugs too but i have absolutely no turbo!
Had missfire problems my self on the passat 1.8t used vag-com on it was coilpack on mine.Changed all 4 as when one goes the rest can go to..And check for vac.leaks or intercooler hose popped off
