No all I done was change the steering angle, turn the car off & back on and cleared the faults and that was it.Other than resetting the steering angle, did you change anything else on steering assistance control unit?
Thank you for the reply! Any idea if their is any type of work around to get it sorted or is that a dealerships job?That fault implies there is an issue with the coding of the lane assist camera.
Uhh no I’ve never had to?Have you ever scanned the front camera?
If im being honest i have no idea of how and what to do, I would need step by step of how to do that…You could try to code the camera based on the equipment your car has installed with the user populated descriptions?
All I done was go into steering 44-basic settings-steering angle. That was it.On the assumption you have not used one click apps any changes you made will be in history
Yes I done full lock right-centre-full lock left-centre and then stopped it.When you did the reset did you turn the steering wheel from lock to lock then back to the centre?
I’ve attached the back up to this if you want to have a look.If you can make a backup in OBD11 and share the output via PM, I can compare the codings/adaptations of related units to the ones I have in my own OBD11.
İf I see something looking off, then you may try to change it and see if it helps.
Also I looked around a little bit for that fault code and saw people talking about camera recalibration and things like that.
So It might not be about the coding.
Take your time! Just to let you know I don’t have ACC only normally cruise control, I have a 2021 seat Leon estate se dynamic I believe not a FROK, comparing the codings of your steering assistance and camera units with the data I have may take some time.
