Cain1412
59
8
I recently posted a thread about resetting my steering angle using OBD 11 which I have now done, I have now got a problem lane assist unavailable static code C10ACF2
If anyone could help!!
Other than resetting the steering angle, did you change anything else on steering assistance control unit?
No all I done was change the steering angle, turn the car off & back on and cleared the faults and that was it.
That fault implies there is an issue with the coding of the lane assist camera.
If you have a copy of the original coding of the camera then it might be worth trying to reapply it.
You could try to code the camera based on the equipment your car has installed with the user populated descriptions?
On the assumption you have not used one click apps any changes you made will be in history
All I done was go into steering 44-basic settings-steering angle. That was it.
If you can make a backup in OBD11 and share the output via PM, I can compare the codings/adaptations of related units to the ones I have in my own OBD11.
İf I see something looking off, then you may try to change it and see if it helps.
Also I looked around a little bit for that fault code and saw people talking about camera recalibration and things like that.
So It might not be about the coding.
When you did the reset did you turn the steering wheel from lock to lock then back to the centre?
I’ve attached the back up to this if you want to have a look.
  • OBDeleven_Log.txt
OK, comparing the codings of your steering assistance and camera units with the data I have may take some time.
Take your time! Just to let you know I don’t have ACC only normally cruise control, I have a 2021 seat Leon estate se dynamic I believe not a FR
