Jan 8, 2008
528
Portsmouth
Anyone know what size all the vacuum pipes are? I want to replace them all for red ones and also tidy up the EGR re-routing! Its a TDi Sport ASV Engine. Maybe if you could tell me what size the vacuum lines on a cupra are? i would imagie they are probably the same!!
Thanks!
AmC
st use 4mm.... that's what mine are.... replacing all with 3mm when I get around to it :D
So the standard is 4mm, guessing internal diameter??
The only reason for fitting 3mm is to keep a tighter grip, much harder to sqeeze on??
And finaly what is the best quality brand of hose to go for? Ive seen hundreds of different ones on ebay!!
Thanks!!
