Deanolfc5times
Recently started having some issue starting my Ibiza MK3 Cupra. Steadily getting worse, also starting to have problems with loss of power etc. Borrowed my mates VAG com and got the above reading. The timing belt and water pump haven't been changed for 43,000 miles so are due, I've booked to have them both changed Friday as I think the timing belt may have slipped, just wondering
1 is the car still OK to drive or do I risk causing further damage?
2 In your opinions will this remedy the problem, fitting the new belt and water pump and resetting the timing.
3 are there any other jobs worth doing while having the this work done Friday, general meintanance or things worth changing while the water pump and timing belt are changed?
Any help would be much appreciated.
Dean
Dean
