DJ Walkers
Ibiza Cupra 247.1BHP
got my vag com working and got all this gubbins dunno what it means! any help much appreciated :)
VAG-COM Version: Release 409.1-US
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01: Engine
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 G 0002
Coding: 10500
Shop #: WSC 47688
5 Faults Found:
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
17968 - Shareware Version. To Decode all DTCs
P1560 - 35-10 - Please Register/Activate - Intermittent
16795 - Shareware Version. To Decode all DTCs
P0411 - 35-00 - Please Register/Activate
18011 - Internal Control Module Failed Self-Test
P1603 - 35-10 - - - Intermittent
16955 - Shareware Version. To Decode all DTCs
P0571 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00000
No fault code found.
17968 P1560 Maximum Engine Speed Exceeded
16795 P0411 Sec.Air Inj.Sys. Incorrect Flow Detected
18011 P1603 Internal Control Module Malfunction
16955 P0571 Cruise/Brake Switch (A) Circ Malfunction
16955 P0571 Could have something to do with your brake light switch. Are they working?
Buy yourself a Vag-Com licence (cheap at today's exchange rate) and get those codes reset. See what comes back.
had a look tonight found the pipe circled rd disconnected so i re connected it to the part circled white
will this be the problem?
cheers
can you not just unplug battery adn leave for 10 mins then plug back in think this clears fault codes if nto reacuring ones anyway.
just on a side note how do you clear them if you have full vag com then?
No, I don't believe battery disconnection clears fault codes.
On the full version, say you have a fault code under the engine module 01. You go into that module and click the button ' clear fault codes'.
