didsi
I Want an LCR!
Aug 25, 2006
123
Leon 1.6 16v. Coming up with vag errors:
Address 01 -------------------------------------------------------
Controller: 036 906 034 DS
Component: MARELLI 4MV 4568
Coding: 00031
Shop #: WSC 06402
VSSZZZ1MZ4R004813 SEZ7Z0C2089799
1 Fault Found:
17961 - Barometric / Manifold Pressure Signals: Implausible Correlation
P1553 - 35-10 - - - Intermittent
Readiness: 0010 0001
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0013313
Shop #: WSC 00001
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Can anyone shed any light?!?
ive cleared the codes and they have come back. seems to affect throttle now. ive done tbr with vag, twice, if im in first with no accelerator on the revs get higher then die and repeat. I suspect the '01 Engine' error is something to do with with exhaust and a pressure in it, the ABS code is obviously abs, but how could they affect trottle
For the first, not exhaust - inlet manifold.
01314 - Engine Control Module: Check DTC Memory
Possible Causes
* Fault(s) stored in Engine Control Module
Possible Solutions
* Check Engine Control Module for Fault Codes
Special Notes
* Engine Control Module stored a Code which influences other Control Modules Functionality.
* To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
i cleared the codes in the engine control module and the abs module. they both came back
