mr-bear
Hi guys. Hope you can help me with this. I've got two faultcodes on my sweet machine. The car is a Ibiza -96 1,4l 8v.
The faultcodes:
00533 - Idle Speed Regulation
09-00 - Adaptation Limit Surpassed
01087 - Basic Setting Not Performed
35-00 - -
If i clear the codes the first one always comes back withing three seconds, the second one comes on randomly.
My biggest concern is the Idle speed regulation because the engine stalls when I lift my foot from the accellerator.
Please help me. What should I do? Got MOT in two days
00533 - Idle Speed Regulation: Adaptation Limit (Add) Exceeded
Possible Symptoms
* Bad Fuel Economy
Possible Causes
* Air Leak between Mass Air Flow (MAF) Sensor and Engine
* Injector(s) faulty
* Fuel Pressure Regulator faulty
* Throttle Body faulty
* Intake Air Filter dirty
Possible Solutions
* Perform Throttle Body Adaptation
* Check Hoses and Pipes to/between Components
* Check Intake Air Filter
* Check Fuel Pressure Regulator
* Check Exhaust Gas Recirculation (EGR) Valve
* Check Injector(s)
Possible Symptoms
* Function Limitation
Possible Causes
* Basic Setting Not Performed
Possible Solutions
* Perform Basic Setting
Special Notes
* When found in Audi A6 (4F): Parking Brake, perform Function Test.
* When found in VW Passat (3C): Parking Brake, perform Function Test.
o If the Function Test does not clear the code, perform Longitudinal Acceleration Sensor (G251) Calibration.
Retrieved from "http://wiki.ross-tech.com/index.php"
Categories: Fault Codes
What module is the 2nd code in?
VAG-COM Version: Release 311.2-N
Control Module Part Number: 6K0 906 027 A
Component and/or Version: MOTRONIC MP 9.0 S005
Software Coding: 0261204055
Work Shop Code: 1037355405
2 Faults Found:
35-00 - -
This is all I got.
If I dont have carb. cleaner, what else can I use?
So I cleaned the throttle house and the engine was running much smoother but I still cant get rid of:
Any suggestions?
hi mr-bear, did you ever find out what the prob was? because i have the same fault codes 00533. any help would be appreciated. thanks.
this is normally a nackerd TB, there is a way to test it but i cant rmember off hand. to basic set the TB you need to go into measure blocks on vagcom, group 98 i think for part electronic throttles, then switch to basic settings, the TB will adapt, take a few seconds, switch back to measure blocks, then exit
