Hi all,
just had faults with the DPF on my altea and gone into limp mode, performed the scan and found this. also tried the forced regen on the filter to no avail. can anybody assist with the codes below
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 018 EC HW: 03G 906 018 EC
Component: R4 2.0l PPD1.2 G 9954
Revision: --H02--- Serial number: SEZ7Z0F3387945
Coding: 0050072
Shop #: WSC 02007 476 11793
3 Faults Found:
008194 - Particulate Trap Bank 1: Efficiency Below Threshold
P2002 - 006 - Short to Plus
Freeze Frame:
Fault Status: 11010001
Fault Priority: 5
Fault Frequency: 4
Reset counter: 40
Mileage: 56162 km
Time Indication: 0
Date: 2000.00.00
Time: 00:15:34
Freeze Frame:
RPM: 0 /min
Torque: 144.0 Nm
Speed: 0.0 km/h
(no units): 8.0
Pressure: 0.0 mbar
Lambda: 19.8 %
Time: 5091.8 s
001137 - Exhaust Pressure Sensor 1 (G450): Implausible Signal
P0471 - 006 - Short to Plus
Freeze Frame:
Fault Status: 01010001
Fault Priority: 1
Fault Frequency: 4
Reset counter: 40
Mileage: 56162 km
Time Indication: 0
Date: 2000.00.00
Time: 00:15:35
Freeze Frame:
RPM: 0 /min
Torque: 144.0 Nm
Speed: 0.0 km/h
Pressure: 0.0 mbar
Text: 136 C
Text: 0 mbar
Temperature: 6.0°C
P0471 - 006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00010001
Fault Priority: 1
Fault Frequency: 3
Reset counter: 40
Mileage: 56162 km
Time Indication: 0
Date: 2000.00.00
Time: 00:16:01
Freeze Frame:
RPM: 0 /min
Torque: 144.0 Nm
Speed: 0.0 km/h
Pressure: 0.0 mbar
Text: 21 mbar
Text: 136 C
Temperature: 6.0°C
