jonathanp
736
Coventry
I have a 2004 mk1 LCR
I need to read the SKC code so I can program an new transponder etc.
Which is best to buy and are there any major differences?
Many thanks
Jon
If you are thinking or getting the cheap Ebay versions I can tell you that VagTacho 3.01 would not read the code from my LCR, neither would Vag Commander 1.4. They worked in a Toledo but not on my LCR or a spare cluster I had from another LCR.
Just been looking at Vag tacho and some sellers say it wont work on Windows 7 and some dont can i take it that none of them will work then.
I have vag commander 3.6 on XP, drivers appear to install ok but software wont connect and read any of the EEPROM's etc. Also tried vag commander 1.4, 2.5, 3 and 5.5.
Does Vag tacho work with the same cable as vag commander?
So when you got the SKC code, how do you actually program the transponder chip?
Also looking at the Vag Tacho 3.01 cable from ebay and it says Opel on it? Does this matter or will it still work with my FR?
Cheers.
