VAGCOM Fault Codes Help
xnox202
1M ST-TLD
Apr 15, 2008
182
Brunei Darussalam
So I had my car VAGCOM-ed, and it seems like there's bunch of codes :)cry:) came up. The feedback of the car with these faults were loss of power, no kick-down switch and basically got my transmission only stucked in 3rd gear (As I have an auto tranny).
Can anyone help me "decode" this? Here goes.
Code:
Friday,19,March,2010,21:40:20:38685
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
   Mileage: 146920km/91291miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 06A 906 018 GD
   Component: 1,8l R4/5V  MOTR AT V01
   Coding: 04030
   Shop #: WSC 00046
11 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
            P1602 - 35-10 -  -  - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
            P0113 - 35-00 -  -
16486 - Mass Air Flow Sensor (G70): Signal too Low
            P0102 - 35-10 -  -  - Intermittent
17953 - Throttle Valve Controller: Malfunction
            P1545 - 35-10 -  -  - Intermittent
00282 - Throttle Position Actuator (V60)
            09-10 - Adaptation Limit Surpassed - Intermittent
00515 - Camshaft Position (Hall) Sensor (G40)
            30-10 - Open or Short to Plus - Intermittent
01165 - Throttle Body Control Module (J338)
            08-10 - Control Limit Surpassed - Intermittent
00670 - Throttle Position Sensor (G127)
            07-10 - Signal too Low - Intermittent
16506 - Throttle Position Sensor (G69): Signal too Low
            P0122 - 35-10 -  -  - Intermittent
00561 - Mixture Adaptation
            12-10 - Adaptation Limit (Mul) Exceeded - Intermittent
            15-10 - Adaptation Limit (Add) Not Reached - Intermittent
Readiness: N/A
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 HN
   Component: AG4 Getriebe 01M    4452
   Coding: 00000
   Shop #: WSC 00046
3 Faults Found:
00268 - Solenoid Valve 6 (N93)
            36-10 - Open Circuit - Intermittent
00281 - Vehicle Speed Sensor (G68)
            03-00 - No Signal
00652 - Gear Monitoring
            27-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 J
   Component: ABS FRONT MK60      0103
   Coding: 0004097
   Shop #: WSC 66702 552 00000
2 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
            003 - Mechanical Failure - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
Address 08: Auto HVAC        Labels: 1M0-820-043.lbl
   Part No: 1M0 820 043 D
   Component: 1M-CLIMATRONIC    X0605
   Coding: 00041
   Shop #: WSC 00046
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
            30-00 - Open or Short to Plus
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 601
   Component: 17 AIRBAG VW5       0006
   Coding: 12599
   Shop #: WSC 00046
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments        Labels: Redir Fail!
   Part No: 1M0 920 821 A
   Component: S5-KOMBIINSTR. VDO V03
   Coding: 04102
   Shop #: WSC 00046
   Part No: IMMO
   Component: IDENTNR: SEZ7Z0Y0891035
   IMMO-IDENTNR: SEZ7Z0Y0891035
No fault code found.
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00007
   Shop #: WSC 00046
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AJ
   Component: 8N Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 00046
   Part No: 1J0959802F
   Component: 8N Tõrsteuerger. FS0002r
   Part No: 1J0959801G
   Component: 8N Tõrsteuerger. BF0002r
   Part No: 1J4959811C
   Component: 8N Tõrsteuerger. HL0002r
   Part No: 1J4959812C
   Component: 8N Tõrsteuerger. HR0002r
7 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
01329 - Convenience System Data Bus in Emergency Mode
01332 - Door Control Module; Passenger Side (J387)
            49-10 - No Communications - Intermittent
01331 - Door Control Module; Driver Side (J386)
00933 - Electric Window Motor; Passenger Side (V148)
            62-10 - No or Incorrect Adjustment - Intermittent
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
00944 - Heated Exterior Mirror; Passenger Side (Z5)
            35-00 -  -
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1M0 035 186 C
   Component:  Radio             0001
   Coding: 00401
   Shop #: WSC 00046
2 Faults Found:
00852 - Loudspeaker(s); Front
00853 - Loudspeaker(s); Rear
End   ---------------------------------------------------------------------
George 3G
KW & Weitec
Jul 28, 2009
465
Herefordshire
I had a load of intermittent fault codes on my LCR when I first had it, and now they have disappeared. I wouldn't worry!
If the car drives fine, don't worry.
xnox202
1M ST-TLD
Apr 15, 2008
182
Brunei Darussalam
Well the codes keeps coming back and I would like to know if anyone had this problem before? As I mentioned, the feedback of the car with these faults were loss of power, no kick-down switch and basically got my transmission only stucked in 3rd gear (As I have an auto tranny).
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Do all of the codes keep coming back or just some...??
With that many fault codes coming up and and if they are all reoccuring I would hazard a guess at a potential ECU communication issue due to the intermitent communications errors.
xnox202
1M ST-TLD
Apr 15, 2008
182
Brunei Darussalam
I got my gearbox sorted though (Kinda), as the wire harness to it was "loose". Replaced the Speed Sensor. It does shift to 4th Gear now, but as more kms I do per trip, then the gearbox starts to act weirdly again.
I've also just replaced my battery just incase if those "Voltage Too Low" is because of it. Didn't came back lately though.
I'm worried about these instead:
P0113 - 35-00 - -
Readiness: N/A
Does it seem to be a faulty throttle body and Cam Position Sensor? How does these small sensors look like?
