VAGCOM key fob issue LCR pls help...
Vin-R
342
Midlands
hi guys, hope you can help me,
as you all know,
one press on the fob opens the driver door only.
two presses on the fob opens all doors inc boot.
dont know if you guys have had this but 9 times out of ten when i double click still only drivers door opens, then after a few presses all doors open. its beginning to get quite annoying now as the car bleeps n bleeps.
what i would like, is on ONE press only, all doors open, not just drivers door.
Is this possible??? my mate has vagcom, and uses it all the time, however this one stooped him, and i have read on here that it can be done
my mate said that i need the "soft coding number." when i asked him what that was he said, "my convenience module has a code and every digit in that code corresponds to what the module has been programmed to do?????? he says with that code he can do it and that i have to be 110% sure its the correct code????
is this so?????? pls help.
cheers
