beezasport
Sold the car to buy a....
Hello guys please could you help my friend with the following fault codes.....we have read up and it seems to be a few things i was wondering if anyone could clarify
the 00544 code is showing on some sites as a DV problem but when i reset the codes and did not start the engine the code shower up again
eek!
cheers
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 06A 906 018 R
Component: 1.8L R4/5VT MOTR HS D06
Coding: 04000
Shop #: WSC 00028
2 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
00544 - Maximum Boost Pressure Exceeded
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 00028
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
