TravisFR
57
Lancaster, Lancashire
So I was trying to put on leaving home lights but I was given the message saying that the equipment number was incorrect and when i looked it was outside of the parameters, i havent previously changed anything in VCDS, when i did a full scan of the car i had a malfunction on the CAN gateway which was
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 138
Mileage: 154810 km
Time Indication: 0
Date: 2000.00.00
Time: 15:45:16
If anyone could point me in the right direction i would be grateful! If anyone knows there equipment number for 09: cent electrics that would also be appreciated
Not enough info. You need to post the complete Auto-Scan details so we can see all the hardware that your car actually has along with their current coding values and any other issues present that may well be related.
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 GQ HW: 03G 906 018 GQ
Component: R4 2.0l PPD1.2 G 4361
Revision: --H52--- Serial number: SEX7Z0H031F0AU
Coding: 0050072
Shop #: WSC 61006 210 88553
VCID: 7AFB1463352A82CEDA7-802F
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006786
Shop #: WSC 04941 785 00200
VCID: 73E539471240F386991-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D51EF3FB4E4E5760F5-8078
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005416068
Coding: 81880F2F00041000431D00000000000000007F075C400000000000000000
Shop #: WSC 18434 020 328969
VCID: 71E9334F685CC1966BD-8024
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 090108 022 0601
Coding: 00056208
Shop #: WSC 18434
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 6
Reset counter: 143
Mileage: 159140 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A04 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPS0PSWY
Coding: 0012340
VCID: 3B75D1677A907BC6811-806E
Subsystem 1 - Serial number: 6333FTS670180128
Subsystem 2 - Serial number: 6343FTS668600118
Subsystem 3 - Serial number: 6353ETS64O65SVNP
Subsystem 4 - Serial number: 6363ETS628O4SVNP
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BK HW: 1K0 953 549 BK
Component: J0527 051 0101
Coding: 0002042
Shop #: WSC 61006 476 88553
VCID: 7CF7127B3F1EBCFEC8B-8029
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 005 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 947 C
Component: KOMBIINSTRUMENT VO3 0750
Coding: 0000401
Shop #: WSC 44509 001 1048576
VCID: 3365F94752C0B386591-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0191
Revision: H16 Serial number: 2000K0810407F1
Coding: E9807F060006020203
VCID: 3467FA5B57CEB4BE40B-8061
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 138
Mileage: 154810 km
Time Indication: 0
Date: 2000.00.00
Time: 15:45:16
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0750
Address 37: Navigation (J794) Labels: 3C0-035-270.clb
Part No SW: 5P0 035 191 C HW: 5P0 035 191 C
Component: RNS310 H15 0227
Revision: 10000000 Serial number: SEZ1Z2K8427875
Coding: 040004010404000000000000
Shop #: WSC 99999 1023 2097151
ASAM Dataset: SE_RNS310 A02007
ROD: EV_SERNS310UDS.rod
VCID: 2B55E12742F0EB46111-807E
4 Faults Found:
1048582 - GPS Antenna
B1054 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
1048587 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 167
1048632 - Antenna 1 for Radio
B1119 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
1048634 - Antenna 2 for radio
B111A 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 127
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1130
Revision: 31008001 Serial number: 00000537579026
Coding: 0000688
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.142 H08 1901
VCID: 3663C05341B2A6AE7EF-8063
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 998000005283CC7F0006850560085F86107C00
Shop #: WSC 02102 476 94331
VCID: 8305E987C2E04306091-80D6
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 02102
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1130
Revision: 31008001 Serial number: 00000054179024
Coding: 0000688
VCID: 3C77D27B7F9E7CFE88B-8069
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000002662546
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000002628395
Coding: 0000144
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
Component: FSE_2P5x H26 0110
Revision: 00000001 Serial number: 00000000006997
Coding: 0000555
VCID: 326BFC43ADDABA8E527-8067
The CAN Gateway most likely doesn't like one or more of the settings you have changed in one of the other controllers.
Hopefully you did an Auto-Scan and saved it before you made any changes. If you did, please post it here.
Also, what version of VCDS are you using?
Has someone tried to retrofit navigation to the vehicle? It looks like you have an RNS310 but that it's not setup and connected correctly.
Navagation doesn't appear to be coded in the CAN Gateway, which is probably what's causing the error.
I would imagine that adding navigation to the installed list in the CAN Gateway will get rid of that error, but that definitely needs more investigation.
The error VCDS gives when coding some controllers about the workshop / equipment ID can usually be ignored by clicking 'No'. VCDS will try the existing numbers which will usually work. Pretty much any value except all zeros will work.
Yes, a log of an original Auto-Scan before any changes will confirm what has changed in the CAN Gateway installation list and what coding values have changed in any other installed controllers. It is always best to refer back to that first before making any further trial and error coding changes.
This also highlights the importance of always doing an Auto-Scan and saving the results before messing with any coding values or retrofitting something so in the worst case you have a record of the original control module coding values and can revert back to them if you need to. I personally also do a dump of the current adaptation values on a controller before changing any of the adaptations in it. You can never have too many logs.
Not necessarily though, as not all CAN Gateway controllers use the long coding to store the installed equipment list. A previous auto-scan would be not use at all then.
Besides, looking at the reset counters on the errors this clearly isn't a fault that the OP has just caused. It's a pre-existing problem.
It would certainly have helped identify what was pre-existing though!
Yes, that's true and I agree. In fact the CAN Gateway in my own car is one that uses short coding but it's clear that the one in TravisFR's car uses long coding so in this case a previous scan could be used to identify any before and after changes to the CAN Gateway installation list. A previous scan would also allow us to see if controller 37 didn't previously exist at all which would identify it as a new addition to the car.
All of this is of course assuming that any changes to cause these faults weren't done by a previous owner.
I hadn't done anything to the car before trying this, this is the only scan i'd done so havent got anything extra, it does have an RNS310, so this needs to be coded in? everything works as it should so unsure how they would have not coded it in?
In that case it sounds like a previous owner did a half-baked job of retrofitting the RNS-310 unit to your car.
You've got nothing to lose now so I suggest you just go ahead and add controller 37 to the CAN Gateway installation list...
  1. Click the [Select] control module button
  2. Click the [19-CAN Gateway] button
  3. Click the [Installation List] button
  4. Tick the [37 - Navigation] item
  5. Click the [Save Coding] button
  6. Close all the screens until you are back at the first screen again
  7. Go to the Auto-Scan screen and select the option to clear all DTCs
  8. Close and exit VCDS
  9. Cycle the ignition off and then back on again
  10. Run VCDS again then do another Auto-Scan and see what faults are still present (if any)
09-Cent. Elect. -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
Coding: 0050072
Readiness: N/A
Revision: 00H11001
Coding: 0006786
Coding: 00056208
Shop #: WSC 18434
Coding: 0012340
Coding: 0002042
Coding: 0000401
Coding: E9807F064006020203
2 Faults Found:
1048629 - Aux IN Socket
B1104 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 142
Mileage: 161320 km
Date: 2000.00.00
Time: 20:01:27
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 142
Mileage: 161320 km
Date: 2000.00.00
Time: 20:01:29
Coding: 0000688
Coding: 00000000
Shop #: WSC 02102
Coding: 0000688
Coding: 0000144
Coding: 0000144
Coding: 0000555
i dont have 2 antennas i presume but i have got 2 aux, centre one and the one on the RNS310, centre one doesnt work but the RNS one does so i imagine thats that fault
that fixed the error on the CAN gateway, any thoughts on the equipment number being too high in cent. electrics?
You will probably need to take the RNS-310 out of the dash and check the connections going into the back of it, but at a guess:-
  1. The two aerials are one for the radio and another for the GPS. I'm guessing that the unit that was originally in your car probably didn't have navigation capabilities which would also mean that your car is unlikely to have a GPS aerial. If this is the case then I would expect to find no connector in the back of the RNS-310 for the GPS aerial. This also raises the question as to whether or not the satnav works OK (i.e. does it sometimes lose its signal?).
  2. As you say, your centre auxiliary socket probably just isn't connected up. Again, checking the back of the RNS-310 unit will reveal if there is anything plugged into the external auxiliary socket connection.
Its not for the GPS as theres a separate fault for that in the previous scan, checked the aux connection and it appears correct maybe the one on the RNS overpowers it?
The RNS-310 supports 2 auxiliary ports. The one on the front of the unit and an external one (i.e. in the centre console) which connects to the back of the unit.
Connector number 6 in the picture below is for the FM2 aerial. Do you have anything plugged into that connector or not?
Pins 1, 2 & 7 of connector 4 in the picture below are for the external auxiliary port. Are the 3 wires that come from your centre console auxiliary port connected to each of these 3 pins?
I have a feeling there's something in 7 and not 6
That would probably explain the "1048634 - Antenna 2 for radio" fault code then.
VAG cars usually have two aerial wires so if only one is connected to your RNS-310 then check to see if the other one just hasn't been plugged in and is hanging down the back of the dashboard somewhere. If this is the case then you may find that you still can't plug it in due to a plug incompatibility issue. If you find this then you will need a Fakra adapter something like this...
If it turns out that you only have one aerial cable in your car then you will need an double-to-single Fakra adapter like this...
Would this be why the signal on radio is pretty poor, sound quality through it is dreadful but to be fair i only use SD card anyway, i'll have a look but fairly certain theres only 1 aerial cable so will need the second adapter
